Results 1 to 12 of 12
Thread: 96 Miata Engine and Components FOR SALE
    Nov 2004
    Default 96 Miata Engine and Components FOR SALE
    Pulling the engine and other components out of my 96 Miata. Here is the list on items for sale. Will sell all as a package or individually. You can drive the car NOW if you would like to feel the power of this engine, but will be pulling it next week. Email me for pictures, questions or come by the shop.
    Engine $750: 115K miles, timing belt and water pump changed at 110K. Engine is clean top to bottom with no oil leaks or even any leftover residue. Rear crank seal replaced with clutch, again no leaks. Engine is set up currently with Racing Beat header, TDR intake and Mega Squirt PNP. RWHP was 125 at the dyno. This engine is my track engine, but the compression numbers below show the solid condition of this engine. Mileage may be high, but not an issue on a solid engine like this. I would have no problem putting forced induction on this engine. Will not include coil pack, throttle body and CAS unit as these components will go back on the new engine we are building.
    Cylinder Compression Leak Down
    1 180 4%
    2 172 8%
    3 178 6%
    4 178 6%
    Clutch $500: Clutch is our SPEC Stage 2 Plus with aluminum pressure plate option (2 lbs less and better at transferring heat from the steel friction plate) and aluminum flywheel, new $900. This is our best street and track setup for non-boosted setups. Stage 2 Plus is our hybrid setup that uses Kevlar on one surface and Carbon Ceramic on the other surface. Clutch feels perfect, no chattering and easy to modulate. Has about 2500 miles on it. Pedal pressure about the same as stock. Can be installed on the 1.6 or 1.8 engine.
    TDR Intake $100: This is our TDR setup using 2 ¾”, 5-ply silicon hose with K & N air filter. New setup is $190. Since engine is setup for the Mega Squirt the hose is longer to eliminate the MAF unit. And has provision for the air temperature sensor.
    Racing Beat Header $300: We installed this maybe 1000 miles ago so virtually new. Header new is $439.
    Mega Squirt PNP1 $350: This is for 96-97 model OBDII Miatas. It includes air temperature sensor currently in the TDR intake setup. New would cost $650. Programming is complete for this current engine setup. Unit is only about 6 months old.
    Gary
    W:214-340-9797
    C: 214-280-6172
    Danger!!! This Dog Bites.
    www.trackdogracing.com
    If that's the header you are talking about, unfortunately I don't think it will work for me as it's probably spaced for the 1.8 head exhaust ports. I got the 1.6 motor. Let me know which one you've got.
    Gary, I will take the engine, clutch and intake.
    Quote Originally Posted by motorollow View Post
    Congrats!
    Yeah, I am keeping the oil companies in business with the amount of oil I am using. Also, my clutch is beginning to clatter more. At 220K miles, its time for a refresh. Its a good deal getting the clutch with the engine since there wont be any labor for the clutch. I will be putting off the NC purchase for a few years.
    I want the intake, if it fits my 99-swapped NA. I sent you a text.
    I am no longer buying the TDR intake and I believe Gary still has it for sale. Let me know if you are interested in my stock exhaust.
    Wish i had the money for the engine...i really need the conversion groom my 1.6
    silver 91 miata - no mas
    gold 91 miata w/ hardtop - no mas
    99 emerald green mica miata - just found!
    Feb 2011
    Fort worth tx...by tms
    I might be interested in the header!
    The engine and clutch are in my car and working great!! Seriously, its like having a new car. Big thanks to the guys at TDR for getting it done so quickly.
    Feb 2011
    Pm sent for megasquirt
    Quote Originally Posted by Bigsrturbo View Post
    You may just want to email Gary directly for quicker response. Gary at Track Dog Racing dot com
  1. WTB 1.8 Engine for my 1996 Miata
    By Fox in forum dfwMiata.com Classifieds
    Last Post: 04-07-2012, 04:17 PM
  2. For sale: 2003 Miata s/c 10000 OBO Motivated to sale
    By Tim the Teacher in forum dfwMiata.com Classifieds
    Last Post: 05-10-2011, 09:02 AM
  3. 1.6 Miata engine
    By cliff in forum dfwMiata.com Classifieds
    Last Post: 10-29-2009, 06:27 PM
  4. 1.8L Miata Engine (1994) and 5 Speed Transmission for sale
    By rlauer in forum dfwMiata.com Classifieds
    Last Post: 08-13-2008, 02:48 PM
  5. some 99 Miata engine parts for sale
    By Maniac Mitch in forum dfwMiata.com Classifieds
    Last Post: 07-01-2008, 10:17 PM
