Did you Seafoam it before going in for inspection?
Well after failing the first time because my fan wasn't working and it overheated....fixed but note the guy said it failed because something to do with my rpms..maybe intake, but they couldn't give me an answer on how to resolve it...what do y'all think it might be?
silver 91 miata - no mas
gold 91 miata w/ hardtop - no mas
99 emerald green mica miata - just found!
M3 is always the answer.
Find a friendlier inspection station...
Was it hot before you had it inspected? Take it out, drive the snot out of it and then take it in.
Bump your timing back and go somewhere else...your going to have to pay again anyway.
Like Sammy said, put a bottle of and flog the hell out of it, get it up to temp.
520,897 posts? Dang.
Do the test with the hood open, but with a HC score that high you probably need a cat converter.
-i seafoamed (put it in gas tank) when i got the car about 2 months ago...
-it wasn't really hot, i just went during my lunch time really quick and left it at the place
-hood was open when he did it
-bump timing (is that an easy process?)
i also have a jr intake, should i install that before i try again?
I'm with Trey, how with old is your catalytic converter.
Well doubt it was ever changed.. And if so its the oem 91 one
It's easy to take off and check out the guts on the inside, when mine went out it was obvious it was time for a new one. Passed every inspection since and that was in 01' or 02'.
Just bought rxp, should i put it in the morn and wait till the weekend to test it?
There is an inspection station just off I35-E in South Dallas on the feeder road that is very easy to deal with. Its right next to Village Fair, if you need help with google, near the loop 12 exit. Also, he's only $29.
BTW - seafoam will do a lot more for you if you run a can through the intake via a vacum hose. Makes a giant smokey mess, but I have first-hand experience that it drastically improved the idle and response on the 91 I recently fixed-up.
How does someone charge less than what the state sets as the going rate?
1. is it ok if i use both products, rxp - gas and seafoam - intake manifold?
2. if i can, which is the intake hose i use to the bottle method on the youtube vid (they had a 1.8 )
http://youtu.be/AW5Rf1Wg-Vs
i really hope i can pass this soon, im like bobbing and weaving the po-po
Have you checked the timing yet?
My '92 wouldn't pass the NOX part of the test until I bumped the timing back to 10. Never bought it a and sold the car with about 180,000 miles on the OEM - YMMV.
Now part of my annual procedure for inspection is to adjust the timing before I do anything else.
sucks to admit this, but i dont know how to do that
