wideband gauge will be removed and possibly the Roadstersport midpipe and Racing Beat muffler and will come off before I sell unless the full asking price is paid.
2000 Mazda Miata - $4100 (temple)
2000 Mazda Miata odometer: 151600
2000 Classic Red Mazda Miata LS
Mileage:151,763 as of 11-03-13
Clean Carfax(no reported accidents) and clear title
2 previous owners all in Texas
Engine Type: In-line 4-cylinder, DOHC
Engine Displacement:1.8L (110 cu in)
Compression ratio - 9.5:1
Horsepower (SAE net) :142
Torque (SAE net) :116
5 speed manual transmission
MPG:22 city/27 highway(many sites show higher like 25 city/28 highway) I average 23-24 mpg city driving and never drove enough highway miles to contribute a number but most Miata owners get what i average or better.
Has a/c and power steering and heat and they all function properly.
LS Model : Tan interior with tan leather seats, tan vinyl top , torsen limited slip diff, power door locks, cruise control, carpeted floor mats, Bose music system, cd & cassette player, door mounted tweeters
LS Suspension Package: Includes strut-tower brace, Bilstein shocks and upgraded front and rear stabilizer bars.
LS Appearance Package: Includes Front air dam(doesn't have the add on lip), side sill extensions and rear mud guards
Inspection sticker good until 09/13 and the registration until 12/13
Have owned since January of this year and it had 146k miles when purchased. It is an absolute blast to drive and look forward to driving it and if you have never driven a Miata and love cars or the driving experience then you need to drive one then you will end up owning one either now or in the future. I currently have over $3K in receipts for performance enhancing and maintenance items and run Lucas Fuel injector cleaner or Berrymans B12 chemtool thru the fuel system usually once a month as preventative maintenance and only use Shell fuel. The car has several small dents and scuffs on the exterior and interior has typical wear for its age but seats are still in very good shape and overall the car is in good condition.Here are the following mods/maintenance done:
Engine & Exhaust
-dry compression test showed 190-195 psi across all cylinders(145-209psi is the range) and a wet compression test showed 210-215psi.
-$30-NGK iridium tip plugs
-$48-Jackson Racing 8mm spark plug wires
-$175-new coil packs
-$129-DDM Works Stage 1 intake
-$235-Raceland header w/ extra o2 sensor bung for wideband sensor
-$300-Roadstersport midpipe 2.5'' w/ magnaflow high flow catalytic converter
-$300-Racing Beat Power Pulse single outlet muffler
-$150-new front and rear o2 sensors
-$18-new oil dipstick
-$2-Puralator PCV valve
Wheels & Tires
-stock 5 spoke 15x6.5 wheels
-Cooper Zeon 195/55/15 (almost brand new)
-$60-949 Racing Forged Aluminum lug nuts
-$100-fenders rolled
-$100-ARP extended wheel studs
-$170-DRT drilled and slotted rotors
-$100-SS braided brake lines
-$95-Wearever Platinum Ceramic pads
-$36-Motul RBF600 brake fluid
-$12-painted calipers w/ red brake caliper paint
Exterior
-$15-front license plate relocation bracket
-$100-replaced rear driver side taillight
-$3-rear license plate lights replaced w/ LED bulbs
Interior
-$300-AEM UEGO wideband sensor
-$50-ATi epod gauge holder(housing wideband gauge)
-$15-interior smoked dome lens replaced w/ clear Mitsubishi lens and a cool white LED bulb
-$38-just installed new nylon window guides on both windows and used lithium grease on tracts
-$6-used passenger air bag switch
-push button start(was installed already)
Total Listed:
$2,585
Total in receipts:
$3,204.33
Car runs great and I have already taken care of a fair amount of maintenance and have a quit a bit of money invested in it and the only isuue is it burns oil but doesn't constantly smoke but it is burning it and not leaking so I suspect oil control rings or valve stem seals. Top also developed a tear right above the window and its repaired and weather proof using clear silicone and gorilla tap on the inside. Please do not contact me with ridiculous offers; Im aware of the cars value(NADA retail is $5075) and what i have in it so $4100 obo is by no means unreasonable. Call Chad @ 254-721-4748 8am-10pm. IF AD IS UP IT IS STILL FOR SALE,so please do not text or email and ask if it is still for sale because no reply will be given due to disclaimer and due to rampant internet frauds, emails will generally be considered an attempt to defraud me so please call or text me. Also the car does have a lien on it so the transaction would have to be finalized at my credit union here locally and a cash transaction is the only way the car title will be released the same day. Thank you for your interest.
Pictures:
http://s21.photobucket.com/user/supe...0%20miata%20LS
Price drop $3600 obo. Mileage 152,023
Some maintenance done:
-$45-replaced passenger side soft top latch
-$45-replaced Nardi leather steering wheel
-$45-Dayco accessory belts
-$35- Trico Neoform wiper blades
Will also replace state registration this month.
