Originally Posted by
Walsted
Probably way out of my league, here, since I was a Ford Turbocoupe guy, not a Mazdaspeed guy, but if it were me...
First, I would look at the OBDII operation, and see if increasing boost or changing compression would throw a code causing an inspection failure.
If not...
If the engine has forged internals, including pistons, I'd look at lowering compression and making up for it with increased boost, provided the injector bandwidth was adequate to keep up with the increased boost given a good enough fuel pump. or the availability of a a fuel pump that could keep up, such as a Walbro 255lph high pressure. The thought process here is that power is provided by the mass of expanding air. For example, 20PSI of boost in a lower compression engine has a slightly higher mass than 20PSI in a high compression engine of the same displacement, meaning more expanding gas upon ignition for the lower compression engine and thus more power.
The Turbocoupe I had was 10psi/155 hp stock; increasing the boost to 20psi and adding the 255lph hp Walbro made it a LOT more responsive, since the fuel pressure regulator was vacuum/boost regulated, and the higher performance pump could keep up until redline in theory. (I never tested it, since that would have been over 170mph. Never had it dyno'ed for actual numbers, but the difference was extremenly evident.) I wasn't worried about the boost pressure, since some guys were running significantly higher than 20psi on forged pistons, (with bigger or more injectors) without ill effects until they had to pay for gas.
In the Turbocoupe world, boost limits are primarily determined by pistons and fuel. Cast pistons (even hyper-u) don't last at more than 10psi on those cars. On the other hand, this may not be true for all cars, since I have seen a reference to turbo Solstices running 18psi on cast pistons. Stock fuel pumps often can't keep up with high boost, which results in pinging and holes in the pistons in the Turbocoupe world.
The general rule of thumb with a TurboCoupe was a pound of boost equals six to ten ponies, probably closer to six. On the other hand, and better for us, a guy I met at the Wednesday night DFWMiata meet told me that the turbo gave him more than 10 horses per pound of boost on his Miata. If that is true, and I could run 20psi on a Mazdaspeed compared to its stock numbers, how much would my gas and tire bills go up if I had a Mazdaspeed?
The folks who know more about Miatas and Mazdaspeeds can probably give you more applicable advice, especially about fuel injector limitations and fuel pressure regulators. Intercoolers also come into play, but the cast/forged switch doesn't affect intercooler choice as much as it does the "how much boost will I run" decision.
I hope this helps, even if the knowledge comes from a different turbo'd car. Hopefully, a bunch of knowledgeable folks jump in and tell me how much and where I am incorrect or it is different in Mazdaspeeds, so we can all learn.
