Those numbers can't be right. Either your gauge is off or you've gotten something wrong. Valve guides can be changed in the car, but they don't have anything to do with compression. They can sometimes leak a small amount of oil onto the valves which causes a !little smoking. Compression issues are either bad rings, bad/burned valves (not seating correctly) or something much worse. Valve guides are the least of your worries if those numbers are right. Consider comparing your valve to another good engine, or try a different gauge. Its also a good ideas to hold the throttle butterfly open to get plenty of air.
