Results 1 to 5 of 5
Thread: Removing crank sprocket
    Chassis Designer
    Feb 2013
    Flower Mound
    Default Removing crank sprocket
    I want to remove my crank sprocket so that I can replace the front main seal.
    There is a video on youtube of a fellow that hammers the key and eventually removes it.
    http://www.youtube.com/watch?v=Wfk5D1sDxuA
    Skip to 40second mark.
    I was thinking that the sprocket should be removable with a small jawed pulley puller with the crank key in place.
    What does the service manual say on this?
    Jay Johnson
    Quote Originally Posted by JayJohnson600 View Post
    Jay Johnson
    Jay, I'm headed to work now. Send me a text as a reminder and I will tell you what the factory manual says tonight.
    AnthonyS
    former owner of 4 NA Miatas
    94 Laguna Blue awaiting Ford 5.0 transplant
    Also have a 91 ZR-1 and 00 996 (911).
    Mine was corroded on there pretty badly. Even with the key out, it would not budge. Eventually had to use a hammer and chisel on the teeth to get it to turn and break loose, which also required a new sprocket.
    Heat and freeze-off worked for my stuck gear. Ymmv.
    Aug 2007
    Fort Worth and Houston, TX
    Blog Entries
    7
    I have had no issues during timing belt changes and seal replacements, but I am very liberal with the PB Blaster. You may want to try soaking all affected parts in PB Blaster before beginning.
    Hope this helps.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
  1. Need Exhaust Cam and Sprocket
    By Sloaner00 in forum dfwMiata.com Classifieds
    Last Post: 11-14-2013, 01:20 AM
  2. Is there a trick to removing ...
    By perry in forum Miata Tech and Chat
    Last Post: 07-27-2010, 04:49 PM
  3. Removing Crank Timing Gear
    By jeepinbanditrider in forum Miata Tech and Chat
    Last Post: 03-22-2010, 08:12 PM
  4. Removing A/C compressor?
    By icepenguin66 in forum Miata Tech and Chat
    Last Post: 07-09-2005, 03:13 PM
  5. Removing the crank pulley
    By brock in forum Miata Tech and Chat
    Last Post: 06-15-2005, 08:44 AM
