The second one you posted, but I can't remember the size off the top of my head. I just did a search to find it when I ordered mine.
Do you mean a vacuum bleeder?
http://www.harborfreight.com/brake-b...kit-69328.html
Or do you mean something like this?
http://www.amazon.com/Russell-639560.../dp/B000CPCOAM
If you're located near TrackDog just swing by and pick up a speed bleeder from them. all you need to supply is an empty bottle. If you're going to Keller's tonight maybe you can talk William into bringing one with him. Or if you're near North Richland Hills swing by and you can borrow mine.
http://trackdogracing.com/tdrbrakefluidbleederkit.aspx
90 Red NA
91 Red NA
99 Triple Black NB "Dimples"
So I decided to pick up a Mityvac bleeder as well as a new master cylinder on my way home from work yesterday. I installed the new master cylinder, bled with the Mityvac & everything is working great. Time to![]()
Do you think the SS clutch line kit is a huge improvement? I'm planning on replacing my slave soon and would like to know if the line is a worthwhile upgrade.
and not having to deal with that stupid coiled hard line or having to contort your arm up to where the soft and hard lines meet is worth the money itself, IMO.
I wouldn't hesitate to switch to SS if I was in the process of swapping the other components anyway, but i also wouldn't go to any trouble to switch. The oem line works fine, and is rarely a problem once properly bled. I personally have never switched one of my own miatas to ss, but I've appreciated the few I've bled that had one. YMMV
