Time for some suspension work. The front subframe and suspension came off the car all together, so first I disassembled it and figured out what would be reused.
The shock assemblies looked pretty nasty.
A little cleaning made a big difference.
The control arms looked pretty dirty and had the original bushing and ball joints in them.
I cheated a little here, as I had a set of control arms off of a 96 parts cart that I had already cleaned and removed the bushings. I pushed new OEM bushings in, replaced the lower ball joints with new OEM ones, cleaned/repacked the upper ball joints and gave them new boots, and then reassembled everything on the new subframe with new alignment bolts.
Everything is now installed on the new sub-frame and ready for bolting in to the car. The lower control arm attaches to the new subframe just like the stock one, but the upper control arms are a little different. Note the zink plated washers on the upper control arms. The kit comes with 12 of them and 6 are used on each side. You can have them spread equally front to back for stock geometry, or you can split them unequally which I believe results in change in castor. Maybe someday I will play around with that, but for now I split them equally.
