Results 1 to 10 of 10
Thread: Coil Wiring
    Aug 2007
    Fort Worth and Houston, TX
    Blog Entries
    7
    Default Coil Wiring
    I just had another junk-yard engine installed. My fuel pump wiring died, so I can't try to start the engine until I get that fixed. That said, the coil connectors look twisted. For those with 99/00 Miatas, which side (passenger/driver) coil connection has the brown/yellow wire, and which side has the brown wire?
    Mike Walsted - Not an expert, just a data point.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
    Aug 2007
    Blog Entries
    7
    Most wiring diagrams I have seen refer to coil 1 and coil 2, without specifying which side is 1 and which is 2. Do you know which side is which?
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
    Wouldn't Coil #1 fire the #1 spark plug (and #4 at the same time )
    I always thought it didn't matter, as long as the plug wires were in the correct order.
    1/4 and 2/3 need to be on the same coils. Miatas use "wasted spark", which is why they eat up plugs and wires faster than many other cars.
    ^That's what I was saying...doesn't matter if it's 4/1-2/3 or 2/3-4/1, depending on coil-feed leads.
    Aug 2007
    Blog Entries
    7
    The problem is that the coils fire at different times. One coil fires when 1 and 4 are at TDC, the other when 2 and 3 are at TDC. The question would be whether Coil 1 (brown/yellow wire) fires with 1 and 4 at TDC and coil two (brown wire) with 2 and 3 at TDC, or is it the other way around?
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
    Brown/Yellow to passenger side, which I have 1 & 4 in. Brown to driver's side, 2 & 3.
    Aug 2007
    Blog Entries
    7
    Thanks, Eric.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
  1. WTB99-00 coil pack and injector wiring harness.
    By PSimonds in forum dfwMiata.com Classifieds
    Last Post: 07-09-2015, 07:59 PM
  2. NC Wiring Question
    By OZMDD in forum Miata Tech and Chat
    Last Post: 06-26-2010, 11:56 PM
  3. iPod Wiring into a 99
    By jolberry in forum Miata Tech and Chat
    Last Post: 02-24-2006, 11:37 PM
  4. wiring
    By Dave in forum Miata Tech and Chat
    Last Post: 12-22-2004, 11:40 PM
  5. Wiring Conundrum - Con't.
    By Treibenschnell in forum Miata Tech and Chat
    Last Post: 12-12-2004, 02:57 AM
