Results 1 to 7 of 7
Thread: Clutch hydraulic fluid disappers
    Driver nealb's Avatar
    Oct 2005
    Texas hilly country
    Default Clutch hydraulic fluid disappers
    I’m not the greatest mechanic so I need help figuring something out.
    Parked the autocross car in November and uncovered it Monday to do some pre-season maintenance
    Clutch pedal went to the floor. Worked perfectly when parked, now nothing.
    Looked at the clutch master and it was totally empty. No sign of leaks on the floor or inside engine bay under the master or around any hose/line fittings or inside the cockpit. Everything dry and no dampness I can see.
    Put a new clutch slave on it Monday afternoon and all is good.
    Looked at it today Wednesday and the clutch master is empty. No leaks or dampness anywhere I can see
    Where did the fluid go?
    Guess I’ll fire the parts cannon again and put a clutch master on it, but WTF?
    Anyone had this happen?
    2009 MX-5 STR and track toy
    Split clutch line from master to slave cylinder?
    Check the firewall insulation under the pedal. If its not leaking there, then I'd have to assume its in the bell housing.
    It's almost always the slave cylinder. It's miata 101.
    Feb 2007
    Propwash 16Xray
    Always change the Master/Slave together….Pull the Master and see if its leaking at the input. :likely:
    Oct 2005
    Texas hilly country
    just replaced the master
    it was shiny wet (not dripping) around the snap ring that holds the piston in the bore
    no fluid anywhere on the firewall, either side
    bled it out and we'll see if it keeps fluid
    love the Motive one man bleeder
    Oct 2005
    Texas hilly country
    three days since replacing the clutch master and all is good so the master must have died with the car just sitting in the garage
    still wonder where the fluid went
  1. General question about clutch fluid and pedal feel
    By jbh in forum OTM Tech and Chat
    Last Post: 03-11-2010, 08:02 PM
  2. Need Hydraulic Line for Clutch Slave Cylinder
    By motorollow in forum Parts is Parts
    Last Post: 01-27-2008, 10:05 PM
  3. Hydraulic Clutch Pressure Problem
    By Korwen in forum Miata Tech and Chat
    Last Post: 02-19-2007, 01:15 PM
  4. Clutch engages early OR ...early clutch release point
    By joe.MIATA in forum Miata Tech and Chat
    Last Post: 02-11-2007, 02:15 PM
  5. Fizzy Clutch Fluid
    By Kiliwizz in forum Miata Tech and Chat
    Last Post: 07-22-2005, 12:12 PM
