Results 1 to 8 of 8
Thread: Suspension help 91 NA
    Default Suspension help 91 NA
    So, I installed my new FM 2.5 coil over set up, which lowered the car a little. Then reinstalled my RB front sway bar with their end links adjusted all the way down, or as short as they would go. Of course all this was done with the suspension hanging. When I took it to the alignment shop they called and said the sway bar was touching the upper control arm. I had them just disconnect the sway and get the alignment done.
    Tonight I modified the end links so they are a little shorter. With the front on ramps and the rear on jack stands, I have approximately 1/2" clearance between the sway and the upper A arm.
    What do you guy's think? Is this plenty of clearance or is it back to the drawing board?
    Which RB bar are you running? Part number.
    I will have to check. I do know it's the hollow one
    Part# 54104
    Half inch clearance should be plenty.
    Thanks Steve.
    I kinda thought it was okay.
    I will be at the AutoX school and AutoX, in Mineral Wells, this weekend, so that should tell the tale.
    That's the correct bar, so it should work. I agree with Steve.
    Thanks guys
  1. STS suspension
    By sammm in forum Autocross Tech & Technique
    Last Post: 11-26-2013, 09:50 PM
  2. New Suspension on my 96
    By tuck4x4 in forum Miata Tech and Chat
    Last Post: 07-17-2012, 10:16 AM
  3. wtb suspension
    By rowlettmx5 in forum dfwMiata.com Classifieds
    Last Post: 03-23-2012, 07:57 AM
  4. WTB: Suspension
    By jakepkoe in forum dfwMiata.com Classifieds
    Last Post: 11-05-2010, 03:23 PM
  5. 93 LE suspension
    By nealb in forum dfwMiata.com Classifieds
    Last Post: 07-09-2010, 12:41 PM
