Results 1 to 5 of 5
Thread: Question about a fuel pump part.
    Default Question about a fuel pump part.
    Recently purchased my 2nd project car. The car has set for 5 years. It seemed the only thing wrong with the car is that it needed a fuel pump. I drained the old gas our of it and pulled the fuel sending unit out of the tank. The fuel pump was bad as thought. I replaced the fuel pump and fuel screen and the fuel filter in the car. At the bottom of the entire assembly is a bracket with a rubber pad or insulator. The rubber pad is falling apart and I would like to replace it but I can't find what part to order. I have attached a link I found on the internet and it is the item #2. If anyone knows what the part number is or where to purchase I would greatly appreciate it. Thank you in advance.
    http://www.mazdabg.com/ftp-uploads/Mazda/--Repair%20Instructions--/323,%20626,%20929,%20Miata,%20Millenia,%20MX3,%20M X6,%20Protege,%20RX-7/7920CH05_Fuel_Pump.htm
    Your link doesn't work.
    Try this one.
    Thanks for getting the image into my post.
    Comes with most fuel pump kits. Call a dealer if you cant find one. Last pump i got from mazdacomp had one included
  1. Fuel sender unit and fuel pump.
    By cortez972 in forum dfwMiata.com Classifieds
    Last Post: 09-14-2013, 06:22 PM
  2. WTB: Fuel Pump Assembly Or Good Used Fuel Pump For 90, 1.6
    By NissanFairladyZ32 in forum dfwMiata.com Classifieds
    Last Post: 10-28-2011, 02:26 PM
  3. WTB: 00-05 Fuel Pump
    By goofygrin in forum dfwMiata.com Classifieds
    Last Post: 07-10-2010, 07:50 AM
  4. FS: 190LPH HP fuel pump mounted in 1999 Miata fuel pump bracket
    By 71dsp in forum dfwMiata.com Classifieds
    Last Post: 05-17-2010, 01:01 PM
  5. Name that problem: Fuel pump or TPS or ???
    By mildensteve in forum Miata Tech and Chat
    Last Post: 04-19-2008, 09:06 AM
