Your link doesn't work.
Try this one.
Recently purchased my 2nd project car. The car has set for 5 years. It seemed the only thing wrong with the car is that it needed a fuel pump. I drained the old gas our of it and pulled the fuel sending unit out of the tank. The fuel pump was bad as thought. I replaced the fuel pump and fuel screen and the fuel filter in the car. At the bottom of the entire assembly is a bracket with a rubber pad or insulator. The rubber pad is falling apart and I would like to replace it but I can't find what part to order. I have attached a link I found on the internet and it is the item #2. If anyone knows what the part number is or where to purchase I would greatly appreciate it. Thank you in advance.
http://www.mazdabg.com/ftp-uploads/Mazda/--Repair%20Instructions--/323,%20626,%20929,%20Miata,%20Millenia,%20MX3,%20M X6,%20Protege,%20RX-7/7920CH05_Fuel_Pump.htm
Try this one.
Thanks for getting the image into my post.
Comes with most fuel pump kits. Call a dealer if you cant find one. Last pump i got from mazdacomp had one included
