Your approach sounds reasonable.
So what is the best method for replacing the Camshaft Plug for those of you who have tackled this task??
I take it you pull the valve cover off and remove the two bolts and slide the new cap in place??
Why remove the VC at all?
Are you talking about the plug that replaces the NA-style CAS?
Not sure about the "Best" method but the "Easiest" method is to call Rogue.
90 Red NA
91 Red NA
99 Triple Black NB "Dimples"
Do it the right way, and pull the V/C.
Thanks Keith, but I'm pretty sure Meesh can handle it.![]()
I guess its tighter in there than I remember. I've never swapped one on a vvt motor in the car, as I've not had one that was leaking. I do reseal them whenever I'm doing a VC gasket, but everything is apart anyway at that point. Shouldn't be a big deal for you.
