Results 1 to 5 of 5
Thread: Home AC issue
    Default Home AC issue
    So I thought I would be a good home owner and clean my outside unit today. It was caked with what looks like years of dirt and dog hair. So I cleaned it off with a glove, and sprayed it out with the hose. I did pay attention to keep water away from the electronics. I got it buttoned up and now it wont start. I could hear a very faint buzzing in the contactor but nothing else. I tried to push the fan with a stick and no dice. I checked both the fuse in the garage and that the outside disconnect looked good. So I go straight to the capacitor. A search here seemed to indicate that is a pretty common problem and I think these units are going on 13 years. That also seems like the cheapest option. Any thing else I should check? Thanks
    The contactors are also a weak link as well as the capacitor.
    What outdoor units do you have??
    Problem solved! I figured I'd use the fancy multimeter I bought a while back and found I didn't have power at the unit. I took the outside disconnect apart and when I used it today apparently the switch decided to break. A quick trip to home depot before they closed and 8 bucks later I'm back in business. Its a rheem, and seemed pretty simple when I had it opened up. I might buy a capacitor to have on the work bench when the time comes.
    Glad ya got it fixed!
    Belated Happy B-Day BTW!
  1. Home network issue
    By sammm in forum Bull
    Last Post: 10-18-2012, 09:39 AM
  2. Fog light issue
    By harley in forum Miata Tech and Chat
    Last Post: 09-02-2012, 07:06 PM
  3. Another Teg issue...
    By MadMonkey in forum OTM Tech and Chat
    Last Post: 12-17-2008, 02:02 PM
  4. Is this the slider pin issue?
    By cam76034 in forum Miata Tech and Chat
    Last Post: 02-08-2008, 08:28 AM
