Preliminary Run/Work order has been set. Based on the current entry level, there will be a 4 heat run/work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event.
Run1/Work3
AS, BS, DS, SSP, ESP, STF, CAM-T, HCS, SM, SMF, AM, FSAE
Run2/Work4
CS, ES, BSP, STR, STU, CAM-S, CP, EP, BM, CM, X
Run3/Work1
GS, ASP, DSP, STX, CAM-C, BP, DP, SSM, EM, FM, W
Run4/Work2
SS, FS, HS, SSR, CSP, FSP, STP, STS, HCR, XP, FP, DM, KM
To balance the worker pool, several people will work in a heat other than posted above. An announcement will be made at the Drivers Meeting.
