Its pretty straight forward....or you can just delete it.
I'm doing a 1.8L conversion, and the motor has an oil cooler.
I can see where there is a line from the oil cooler to the rear of the motor, but where does the other port connect to?
Was it connected to the throttle body and then some point on the block ?
Any got a link to a web diagram for this?
Jay Johnson
Cooler to back of the head
TB to Cooler
TB to thermostat
Thermostat to mixer
ok, I'll see how that works.
Never thought I would connect an oil line to a coolant port.
Hmm then I need to find out where the coolant port(with oil in it) gets back into the block. I have no hoses on this 1.8L motor.
Jay Johnson
Ok, a friend has straightened me out.
Those ports on the cooler are not flowing oil, it's flowing coolant, as one side of a heat exchanger.
Jay Johnson
