Results 1 to 5 of 5
Thread: 1.8L conversion and the oil cooler
    Chassis Designer
    Feb 2013
    Flower Mound
    Default 1.8L conversion and the oil cooler
    I'm doing a 1.8L conversion, and the motor has an oil cooler.
    I can see where there is a line from the oil cooler to the rear of the motor, but where does the other port connect to?
    Was it connected to the throttle body and then some point on the block ?
    Any got a link to a web diagram for this?
    Jay Johnson
    Feb 2007
    Propwash 16Xray
    Its pretty straight forward....or you can just delete it.
    Feb 2007
    Propwash 16Xray
    Cooler to back of the head
    TB to Cooler
    TB to thermostat
    Thermostat to mixer
    Chassis Designer
    Feb 2013
    Flower Mound
    ok, I'll see how that works.
    Never thought I would connect an oil line to a coolant port.
    Hmm then I need to find out where the coolant port(with oil in it) gets back into the block. I have no hoses on this 1.8L motor.
    Jay Johnson
    Chassis Designer
    Feb 2013
    Flower Mound
    Ok, a friend has straightened me out.
    Those ports on the cooler are not flowing oil, it's flowing coolant, as one side of a heat exchanger.
    Jay Johnson
  1. Oil Cooler Input
    By OZMDD in forum Miata Tech and Chat
    Last Post: 09-16-2016, 11:47 AM
  2. Oil Cooler
    By Rogue in forum dfwMiata.com Classifieds
    Last Post: 08-04-2014, 06:29 PM
  3. NB HID Conversion?
    By gabkwong in forum Parts is Parts
    Last Post: 05-13-2010, 03:27 PM
  4. Cooler A/C
    By Walsted in forum Miata Tech and Chat
    Last Post: 08-04-2008, 05:18 PM
  5. Who uses an Oil Cooler?
    By SilverToy in forum Miata Tech and Chat
    Last Post: 06-19-2007, 11:46 AM
