Results 1 to 3 of 3
Thread: TX Region SCCA Autocross #8 - Sunday, October 7, 2018 - TMS Infield Road Course
    Default TX Region SCCA Autocross #8 - Sunday, October 7, 2018 - TMS Infield Road Course
    8th autocross of the year: TX Region SCCA Solo #8 - Sunday, October 7th.
    Where? Texas Motor Speedway Infield Road Course in Fort Worth, TX.
    Event #8 Schedule:
    •Registration & Tech Inspection: 7:30am - 8:30am (PLEASE DON’T BE LATE)
    (If you are new to TX Region SCCA events, please be AT THE SITE by 7:30am)
    •Course opens: 8:00am (approx.)
    •Novice Walk thru: 8:30am (approx.)
    •MANDATORY Drivers Meeting: 9:00am (approx.)
    •First Runs Start 9:30am (Approx.)
    •Trophies (and BEER ) approx. 30 minutes after conclusion of runs. (approx. 3:30 PM)
    Online Registration closes Friday night, October 5th at 11:59pm.
    **NO Walk up registrations are allowed on site for this event. Online registration ONLY.
    Online Registration Link:
    https://www.motorsportreg.com/events...ca-solo-375893
    All this information and MORE is available on the Texas Region SCCA Solo webpage:
    http://www.texasscca.org/solo
    **Running on the road course brings with it some special requirements – you must have autocrossed at least 3 times in the current year to be eligible for this event. (clubs other than SCCA qualify) We’ll be checking local results when you sign up, and will contact you if we can’t verify that you meet the prerequisite. This is a safety issue for us – not so much for the drivers, but for the workers. The Road Course is a large venue with workers spread out over long stretches. It’s important that the worker pool be experienced in this situation.
    This event will be online registration only. THERE ARE NO WALK UP REGISTRATIONS PERMITTED. This is necessary for us to verify your experience and it also helps us plan a better event for you! Because of the expenses associated with such an awesome venue, there is a $15 registration fee increase for the road course.
    NRH, TX
    Preliminary Run/Work order has been set. Based on the current entry level, there will be a 4 heat run/work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event. To balance the worker pool, several people may work in a heat other than posted.
    Run 1 / Work 3
    DS, FS, SSP, BSP, ESP, STH, STX, CAM-T, SMF, SSM, FSAE, SSC
    Run 2 / Work 4
    SS, BS, ES, STR, HCS, EP, XP, AM, BM, CM, DM, W, X
    Run 3 / Work 1
    AS, CS, HS, ASP, DSP, STS, CAM-C, BP, CP, DP, EM, FM
    Run 4/ Work 2
    GS, SSR, CSP, FSP, STP, STU, CAM-S, HCR, FP, SM
  1. Replies: 7
    Last Post: 10-10-2017, 08:44 AM
  2. Replies: 17
    Last Post: 10-12-2016, 05:09 PM
  3. Replies: 14
    Last Post: 10-27-2015, 06:59 AM
  4. Replies: 29
    Last Post: 09-29-2014, 09:41 PM
  5. Replies: 75
    Last Post: 10-28-2013, 01:27 PM
