You can try Mazda Haven. I know they have several trashed tops but still have the latches. May be able to find a good set.
Yeah, so it looks like I'm going to be a parts horder for two cars now. It's been one of my dreams for years.
Whatever...
So the stock softtop latches seem to be falling to pieces before my very eyes. I was entertained to find that I didn't even need to open one after work to drop the top.
Since I need something workable to keep the top closed pretty quickly, I'm guessing it's to the dealer I go ($$$) unless someone has a pair they'd like to sell or donate over the weekend. Any takers?
Drop me a PM - I've got a pair off of my hardtop I'll let go for a reasonable price.
You know they are adjustable, right? How are they falling apart? One of my plastic pieces that holds the adjuster tight broke, so every now and then I have to tighten it back down.
Smile![]()
just3r - what exactly isn't working on your's? I don't mean to hijack your thread, but my passenger side won't lock when the top is up. In other words, I don't have to release the safety button to open it. The latch works properly when the top is down. I've tried the adjuster, but it doesn't seem to make any difference.
Depending on what the problem actually is, here are a few fixes that may help.
http://www.bobhotaling.com/toplatchfix/index.htm
http://memimage.cardomain.net/member...0_359_full.jpg
Thats a high dollar part for sure hope you can get them fixed or replaced cheap.
I almost fell down when I saw how much they cost...lol
99 Miata Black
I had guessed they were adjustable, but didn't know for sure, to answer that question.
As to what's happening with them, well, it seems like all of the visible plastic parts have cracked or broken within the past week or so.
The main part(s) in question would be some semi-cylindrical plastic bits with a flat facing on one edge. 3 of the 4 of these are broken to some extent. I asked about one other piece while at Pennington: a pyramid-shaped sheath (for lack of a better word) that fits between a point on the clamp and the concave receiving point on the windshield surround. One of these fell off a bit more than a week ago, and the other is about to do so. All are small pieces and no doubt minor, but I'm concerned nonetheless.
Maybe I'm overreacting somewhat, but at least with an additional pair of latches I'll get the chance to fiddle with the older ones to see how they work. Everything is a learning opportunity, after all.
Thanks for the help, guys!
I headed out to Cleburne to check out a black '96 for a friend. I thought at the time that I should examine the latches to get a feel for what they should look and act like.
Sure enough, I've now learned that all I actually need is a plastic piece that clips into the inside of the latch. Also learned was that I should lose the recently acquired habit of zipping up the window before closing the top.![]()
Thanks, that's what I need to do. Drivers side no longer locks.Originally Posted by sammm
You should zip it before latching. Puts less stress on the zipper. Raise, Zip, Latch. Unlatch, Unzip, Drop.Originally Posted by juxt3r
I've got bunches of them.......$15 ea.
