Owner's manual? Too bad you didn't ask sooner. I would have gladly changed yours if you had swapped the ones in my wife's Civic... Those are a serious PITA!!!!!!Originally Posted by riverracer
How do I get the bulb out?
Highlight Silver & Tan 99"With a Style Bar"
http://www.cardomain.com/id/riverracer
Member AARP & Meals on Wheels.....
Everything else just "Depends"........![]()
I don't have one....![]()
Just go to any hardware store they all sell hammers!Originally Posted by riverracer
That looked like a special Brit hammer...Originally Posted by POS Racing
TC I know about the Civic... I have one....
Now tell me about this car...![]()
I got an '02... much more room.
Same principle as the Civic... unplug harness, remove seal, unclip bulb, remove bulb. Never touch bulb glass. Never handle hot bulb. Or, if really bored, get bulb hot, quickly remove, and drop in (large, distant) bucket of ice water.
thanks...
It should be detailed in the owner's manual... Maybe someone has one and can check the specifics (like the Civic trick where the power steering reservoir is quick release so you can pull it out of the way...)Originally Posted by riverracer
I'm scanning it now!Originally Posted by tailchaser
I got it out...It was the passenger side...more room there...![]()
Fancy that... bang on identical to the Civic... shocker with it being the same bulb, and all...
It was easier than my Civic....The clip didn't fall off and make me look for it..Thanks POS & TC
Would you expect any less from the "slightly cynical and abrasive, but extremely helpful" Miata board?
First time I changed the Civic lamp, I sent the driver side spring into another zip code. Learned to use a flashlight...
I got just what I expected TC....A little friendly banter and then the answer...![]()
