So far, so good. The crank journals are going to need some minor refinishing due to the rod bearing damage, but other than that the engine was in good shape.Originally Posted by POS Racing
icepenguin, I'm not going to go so far as to suggest that there is an inherent flaw in the engine. As General Default pointed out, I did experience a lower than expected oil pressure reading at a particularly hot event, and that reading was - as near as I can recall - around the same time the noise started. At this point I'm willing to suggest that overfilling the crankcase by half a quart or so, couple with diligent monitoring of the oil level and pressure during events should probably stave off any damage. I'll probably even try Royal Purple or some other single weight oil just to see if the oil pressures are more stable during events with a single weight oil.
The rest is just supposition. There is probably a higher possibility of oil foaming in an autocross environment than street or open track use, but that's just a guess on my part based on my (limited) understanding of what goes on in the crankcase during high frequency, high G maneuvers. I have no real evidence to base that theory on.
Let's go racin'
