Now thats the ticket...
I ordered 2![]()
				$50 gets you a board with some LED's on it and 8" of wiring to connect to the harness. You have to figure out how to modify your light to install it. I chickened out, not worth the trouble.Originally Posted by black roadster
I bought a 1156 replacement bulb from LEDtronics just 2 weeks ago for $20. It fit the CHMSL and met my expectations. You can get similar replacements at Pep Boys but they are dim. I would've replaced all the taillight bulbs if Mazda hadn't used those weird bulbs.
I ordered 2![]()
Highlight Silver & Tan 99"With a Style Bar"
Everything else just "Depends"........![]()
its way cheaper if you make your own...
Linkie
Was it as bright as the original bulb??Originally Posted by Darron65
Those are fairly popular with the Mk 2 & 3 VW crowds... they get fairly good reviews.
Plus LED's don't burn out like regular bulbs either!Originally Posted by Treibenschnell
"Never" ???Originally Posted by icepenguin66
Well, at some point but they should last at least 10x longer than conventional bulbs. I vaguely recall that LED's can last up to 5 or 10 years, right? I know I've been through a handfull of turn signal bulbs and so on in the past 5 yrs. Bulbs are cheap but would be nice to know I don't have to worry about a bulb burning out and having aOriginally Posted by riverracer
with a chip on his shoulder to tell me its out.
Thanks for the info...That means the 20 bucks for the bulb was a good deal after all....
It may out live me.....![]()
Shoot the one in it now would outlast you!Originally Posted by riverracer
He shoots... He scores....Originally Posted by POS Racing
Thank you! Thank you!
I'll be here all week! Try the Veal and don't forget to tip your waiter!
ok I got the bulbs today.....and the verdict is.....
I don't think it is as bright. The LED bulb is red and it has to go thru the red lense. That seems to only make it redder and not brighter. I guess we need two cars side by side to really tell the difference in brightness. The LED bulb doesn't light up the whole assembly either. Just in the middle. A clear lense might be better. What do you people think?
Jerry
Well, install one in one taillight and leave the other one stock... get a volunteer to stomp on the brake pedal while you take some photos comparing the two. Then you'll (and we'll) have some ideas as to how bright they really are.
bean they won't work in the tail lights.... just the third brake light
Well, you could still take some before and after photos, no? That might help...
i tried that too
The pictures sucked....![]()
Post up what ya got! Maybe it's just your camera?Originally Posted by riverracer
You got a Red LED?? Wonder if that may be part of the issue?? Did they offer clear?
