I run the FM front bar(15/16") and no bar in the rear, but I also don't have the STB. Though I am considering getting one when I get new springs/shocks.
I have it set right now with the front bar in the tightest hole and of course the rear bar is non-existant and that seems to give the car a nice neutral balance, yet still tight at the same time. Once I get the STB/springs/shocks I will see how it handles but my current thinking is that I will knock down the setting on the front bar to the other- more loose- hole to compensate for the extra bracing on the front end from the STB as not to induce more understeer.
How much did that brace run you from TDR? The ones I've seen from Good-Win Racing typically run in the $100-$150 range iirc.
