I'm wondering if you have a water pump that is having shaft bearing issues or an issue with one of your accessory devices that is causing the belt to hang/slip. Any groaning, chirping, grinding, squealing noises from up front?Originally Posted by TheChadVIII
As for the driver's side lock... you probably need to clean out the old grease & relube the assembly. I had to do that on my old 92 Blue.
