The only one I have used is a can about the size of an aerosol paint can, but it has a screw top.
I went to Autozone today and picked up some seafoam, but all they had was the deep creep aerosol can. I searched here and theboard and I could not find too many refrences to the aerosol type, just another type. Is this the same stuff? or should I make another trip to Autozone to exchange it?
				O'reilly's has the liquid stuff.
I've used both liquid and the deep creep. The deep creep is actually easier to regulate the amount of to ensure you don't kill the car prematurely. It is the same chemical in a different delivery.
+1 it even says it on the can "Deep Creep" is Seafoam in a spray can"
I have found though that the last 1/5th usually runs out of propellant and remains wasted in the can.
That being said its real easy just to poke the spray nozzle in and start spraying.
99 Miata Black
Where and how did you put it in?Originally Posted by Billy Blaze
You may want to get some help on this one.Originally Posted by blackzx3_13
I know that he sprayed it into his throttle body and a vacume line, but I don't know what vacume line.Originally Posted by POS Racing
Your the same kid who couldn't put the wheels on a Ford Focus without busting lugs IIRC. You may want to get some adult supervision to help ya the first time around.Originally Posted by blackzx3_13
It was the wheel studs, and that is a common problem on focuses. My friend's dad seafoams thier cars like once a year, I just don't know what vacume line to use. There is a diagram on the pointy board, but its hard to tell what is what and its a 93 motor in the diagram
Hey Mick... I heard once that referring to an adult as "kid" is definitive proof that you are over the hill.Originally Posted by POS Racing
I'm nearing the downhill side, what's your point??Originally Posted by Titus
Or something like thatOriginally Posted by Lowell George
If you have Cruise Control, use the C.C vacuum line that runs to the intake manifold. If you don't have C.C., use the capped off nipple on the Intake Manifold that the C.C. would have gone to. On the 1.6, the nipple is front top center (above where the TB attaches)... not sure where the 1.8 nipple is.Originally Posted by blackzx3_13
Thank you.Originally Posted by Titus
Dang... Did he tell you to spray it on your nipple? That's just cold...Originally Posted by blackzx3_13
Hey... I'm just passing on what I learned from watching you and Bean do it to each other.Originally Posted by tailchaser
BUUUUUUUURN!!!![]()
09 Lexus RX350
.... no Miata
Then Titus heard one of them say, " I wish I knew how to quit you."
Wow... Did you forget? You are getting old... The whole thing went down on your property, with your blessing. I'm pretty sure you even participated in the flogging that took place just after the nipple spraying.Originally Posted by POS Racing
