Aftermarket Air Intake Systems (AIS) and Thermostatic Air Cleaners (TAC)
1996 and newer vehicles do not have a Thermostatic Air Cleaner (TAC) system. The TAC system went away on 1996 & newer vehicles, because these vehicles are equipped with OBDII (On-Board Diagnostics – Second Generation) computer systems and these vehicles have more sophisticated fuel injection systems and emissions control systems, so there’s no need for a TAC system. There are several different brands of aftermarket open-type air filter/intake systems by
K&N, Airaid, AEM, etc, so these are OK to install on any vehicle that did not come factory equipped with a TAC system and you will pass the visual emissions component inspection.
NOTE: If the air intake system reads "For Racing Purposes Only" or "For Off Road Use Only" then it is not intended for use on public roadways and is not street legal. If the air intake system is
CARB approved and 50-state legal, then it is street legal in all 50 states.
1995 and older vehicles that are equipped with a TAC system are required to have all the components in place in order to pass the visual emissions component inspection, which is part of the annual safety inspection. The TAC system consists of the enclosed air cleaner/filter assembly and a heat shroud at the exhaust manifold and then there is also a heat duct hose that connects from the heat shroud to the air cleaner assembly. Also, some of the TAC systems had a fresh air duct hose that attached from the front or side of the air cleaner assembly to either the front or side of the vehicle. The TAC system is a closed-type air cleaner/filter assembly and it was designed to reduce Hydrocarbon (HC) and Carbon Monoxide (CO) emissions during cold engine operation, so if your vehicle came equipped with a TAC system and if it was removed and replaced with an open-type design air filter/intake assembly, the vehicle will fail the visual emissions component inspection.
