Sorry... I'll be out of town.
Hey guys,
Still haven't gotten the engines swapped out on the spec project car and could use some help with it. If I don't get it swapped out soon, I'll end up spending the roll cage $$$ on something else.
I'll be working on it on the 21st to disconnect everything and drain the fluids and would like to find some help on the 22nd to swap out the engine/trans as a single unit.
I can fire up the grill or order pizzas, your favorite beer/soda, and fire up some arcade games too. (Pole Position II, Sega Turbo Outrun, Pit Fighter, and Combatribes)
Any takers/helpers? I have tools, air compressor, engine hoist, 4 jack stands, floor jack, and a driveway that will hold 4 cars if you want to make it a tech day. As a plus, AutoZone is less than a mile away.
i would be game for this but i only work on weekends now...
best of luck with it though.
Can't get there without getting the car running better! Once I get the motor swapped and the roll cage in, I'll be participating in AutoX, a couple of DEs, and other events to get more seat time.
I also have a couple of resellers that have memberships to MSR so I can go on member days.
Raymond
+1 (Hallett)
I may be able to swing by after refing hockey.
That'd be much appreciated if you could!
My schedule had freed up. I can come help. PM me with the where and when. See you there.
Doug
I can help that day. Do you have high speed internet and/or wifi at your house? I am on call that day and need to be able to get into work if necessary.
Also PM me directions. I live not to far away on Hebron in Carrollton.
Thanks guys,
Info has been PMed!
I'll be starting around 10am but get there whenever you can. My plan is to disconnect wires & lines from the engine and drain the fluids on Saturday to make things go faster on Sunday.
Raymond
It's IN!
Whew... We had a few challenges on the way but worked through them. Got the transmission filled with oil and almost everything back together as the sun set. Went to turn the key and wirrrrr...rr..r...
Need to charge the battery. DOH!
That's what I get for leaving it sitting for so long without driving it. Just didn't feel like driving it with the oil pressure issues.
Still need to tighten down the front sway bar and put the outer shift boot back on.
Hopefully I can get the charger on it Thursday and get her cranked up & running.
Thanks to Hudson Hawk and Icepenguin66 for the help today! I'll be happy to return the wrenching favor.
Raymond
Your welcome. I actually learned a lot for my future work on the wifes car.
No problem, hope ya get it fired up soon!
And with great looking oil pressure readings!
Got the battery charged and crank crank crank cranks... nothing...
Troubleshooting 101: need gas, spark, air... coils and wires are correct. It's not trying to turn over so check the AFM, CAS, and coil pack wiring. All good. Check fuel... hmmm... strange... looks funny...
Yup.
Fuel lines reversed.
It's funny how much pressure builds up in the fuel lines and how far that little squirt of gas will travel when you pull off the pressurized side. 7 feet from the nose of the car is the garage door. It got hit. Not much gas at all coming out but what came out sure was under some good pressure.
She cranked right up! Now to get the clutch bled and the exhaust leaks fixed (crack in the manifold and one stripped hole in front of the cat) to get her inspected and re-plated... then off to the cage installer!
Thanks again for the help guys!
Raymond
Hmmm... Now that I think about it... I should've have been typing all this from my work laptop with gas on my hands. Those damn detectors at the airport will go nuts from this.![]()
Wow... What a PITA.
Have you ever had a clutch slave that couldn't be bled? The slave was clogged up with crap and no fluid would come out the bleeder.
I swapped the slave from the old engine/transmission and ran a bunch of new fluid through the system using the vacuum pump bleeder. Even got the kiddo involved in the repair. He pumped the clutch pedal to get the remaining air out of the system.
