It comes out in 2 pieces. You need to separate them from under the car, with the lower piece dropping down and the upper have coming out through the engine bay. Be sure to spray all the bolts with PB Blaster several times over at least 24 hours before removal. You will also be much better off with an impact wrench and several different sizes of extensions to get at the bolts that separate the two pieces.
