I assume you have already tried the OBD1 computer reset method, but just in case; disconnect the ground lead from the battery for 5 minutes. Upon reconnection, the ECU will return to default. Also check for any piggyback "chips" spliced into the water/air temp sensors and leads. Those things just trick the computer into thinking there is cold ambient temperature, potentially altering fuel delivery.
