Results 1 to 11 of 11
Thread: Broken Steering Rack Boot
    Default Broken Steering Rack Boot
    I got under the car today and noticed my passenger boot is split in two.
    Do I need a whole new rack or can I just get a boot?
    Any idea on cost for repair?
    Anyone have experience with repairing/replacing this and want to help a brotha out?
    Here you go.
    I would suggest doing it soon, a boots cheap and a rack ain't. If I recall correctly, I thinlg there is a tube of special grease you are supposed to use like a CV boot, but it has been about 15 years since I have done it and I had a lot of problems to fix with the FIAT. I have'nt done them on a Miata, but a FIAT X-1/9 was'nt that hard.
    You will probably need an AJ Special once you are through.
    Last edited by Radio-Active; 03-12-2007 at 03:53 AM. Reason: Replace ebay with local seller
    More info.
    I did check the fluid level and it was about half. I topped it off.
    Just checked. Mine is split too.
    Quote Originally Posted by cam76034 View Post
    Tech day!!!
    No other insight into ths? Certainly I am not the first one to experience a broken rack boot. Didn't Iain replace his steering rack?
    Will a simple boot replacement fix this or do I need a rebuilt rack?
    If your steering feels fine, and is quiet while turning, a just boot will be fine. This part is not a seal of any sort, just a dust cover.
    1984 Honda VF1100S. V4 Fury!
    Yeah, but I replaced mine because the rack was worn. The boots were fine on mine, so I undid the wire ties, moved them over to the new rack, and zip tied them back in place.
    Group buy and tech day.
    Quote Originally Posted by Sharpie View Post
    I take it you have the same problem?
    So how does one seperate the ball joint? The shop manual says you need to use a special tool.
    I'll call Town North tomorrow to check on prices for the boots. I'll also check ball joint boots too as they will be an easy thing to replace at the same time and likely will be cracking soon anyway.
    I believe there are three boots on the rack. One on each tie rod and one at the steering column.
    Why the Ball Joints? If I were going to all of that trouble to break loose the ball joint I would just replace it, because it's a PITA.
    All you should need to seperate is the tie rod ends. You can rent those tools from Vattozone or buy one for about $30. I might even be persuaded to lend you one of the tools.
  1. Just ordered a new steering wheel
    By MiataMike in forum Miata Tech and Chat
    Last Post: 03-07-2007, 02:06 PM
  2. Power vs. Manual steering
    By trickyrix in forum Miata Tech and Chat
    Last Post: 11-15-2006, 09:10 AM
  3. replacing the steering wheel and ditching the airbag
    Last Post: 11-04-2006, 11:06 AM
  4. Dash cover under steering wheel broken
    By black roadster in forum Miata Tech and Chat
    Last Post: 12-28-2005, 03:02 AM
  5. Alignment Issue regarding Power Steering rack
    By fueg0 in forum Miata Tech and Chat
    Last Post: 11-06-2004, 02:43 PM
