You probably need to do a Bose-ectomy. I don't think you can just swap out speakers in that system. Do a search on Miata.net. I know I've seen plenty of threads about removing Bose.
See this - http://forum.miata.net/vb/showthread.php?t=227638
I completely rewired and installed a new sony system in my 99, connections checked, ground verified. upon turning the stereo on the drivers side speaker does not work, pulled speaker and placed on floor board works fine. I left the stero on and as soon as the edge of the speaker made contact it made a fuzzy spark and quit working. the speaker wire did not make contact just the metal frame of the speaker. I actually hooked up the old blose speaker and touched to to the door frame and no spark and it worked fine. Help please.
I completely rewired and installed a new sony system in my 99 stereo, speakers, wire and all. Only thing i reused was the 12v power supply, ground and the ant activation and those were cut from harness and rewired.
sound like your shorting to the speaker frame. It is not a problem until you ground the frame to the car chassis. Are you sure your wires for that speaker are hooked up correctly?
Hudson this is my hunch I think the speaker is internaly miswired or flawed just do not know how to prove it. I know many times in the past i never paid attention to speaker polarity this time I did. do you really think that reversed wires on the speaker would do this? maybe I did mess the polarity up who knows. All I know is that I get a spark from a speaker and that in itself is crazy.
Yes Then What?
Sorry guess you failed to read the post chicken waver . the speaker works fine when NOT touching metal. any more fair feathered ideas I'm game no pun intended.
No reason to be mean spirited I like my eggs fried not my radio. well the real deal is this; the factory soldering of the terminal to the fiber board ran onto the rivet that hold the fiber board on the speaker frame shorting out the speaker lead when touched to ground. Nothing blown or fried what a relief. have a good one.
