..perhaps you should losing that batter holder you have so it can breathe :-P ... Ok...J/k
Start the car and then unhook the negative battery terminal. If the car stays started then your Altenator is still good; and you need to replace the battery. If it dies then the Altenator is bad; and needs to be replaced.
Good Luck.
