They sell a plastic epoxy at Home Depot. You might try that.![]()
Has anyone seen a Mazda Millenia S junker in any junk yard around here? Mazda Heaven at Fort Worth saying they have a junker but is not sure it even has this part on it or the condition of it. Perhaps if anyone of you heading out there anyway please take a look of it to see if it worths my trip to drive through 2 counties to get it.
I need a coolant reservoir. There is leak at the outlet tube area in mine. Or does anyone knows if it is possible to repair this plastic coolant reservoir?
Thanks!
Gabriel
...or JB Weld?
+1 for the JB weld. Just make sure you really clean the surface and put some scratches accros the crack so the JB or epoxy can get a good hold.
'06 RSX Type-S NBP
I did the epoxy. The plastic of the outlet tube is severely aged and has pieces missing and many crack lines. I think the copper tube inside contributes the aging of the plastic. It expands and contract bigger than the plastic. Anyway, I kind of rebuild the tube with epoxy.
I think I over tighten the hose clamp a little. I heard a small cracking noise on my last turn of the screw driver.It is holding OK so far; 10 minutes of warm up on the drive way. It is still kind of slightly wet around the area. I believe if the epoxy have more "give" would be better for this job. I still need a replacement tank sooner or later.
Thanks for the advice.
Gab
Gabriel
