Remove the inner liner. There are one or two 10mm nuts holding the light on. Remove those and pull the whole light housing from the outside. Use some pressure since there are two plastic clips that also hold the housing in. Once it pops out you can see the back of the bulbs and it is cake from there.
 Let's go racin'
