no you do not need to reprogram them when you rotate. some wheels can accept the sensors depending on the desighn of the wheel and if it is a valve stem mounted sensor or a band type. i have to fool with these things all day. you may be able to deactivate it with the factory scanner if you go aftermarket wheels that wont fit the sensors
