First, are you sure it is really running lean? The tail pipe sniffers used at dyno shops will often read lean because they are after the CAT.
If your stock 1.6 really is running lean, then something is wrong... adding an AFPR will only mask the true problem. I would start by checking the actual fuel pressures to see if you have an issue with the fuel pump, filter or the stock fuel pressure regulator.
