PM Sent.
My car didn’t want to run today, it kept dying unless I had my foot on the gas like I had a vacuum leak or something. Checked all my hoses and was stumped. Finally kept it running long enough to get out of the car and look under the hood and to my horror the crank was wobbling so bad the pulley looked warped. I guess now I have to pull it off and see how much damage has been done.
More than likely I will be looking for a 1.6 motor w/ a long nose crank. Anyone have any ideas on where I might find one?
PM Sent.
I'm wondering if I can just rebuild this motor and put in a long nose crank from a 92-93?
I think Channelmaniac might have done something like that. Raymond? You awake out there?
Ive got a long crank, with a good key.
sounds a lot like what mine is doing.
99 Miata Black
I haven't done it yet... I have a spare crank and was going to do it but haven't had time yet.
The motor I pulled from the spec had low oil pressure issues so I was going to see if it just needed new bearings or if I needed to put in the other crank.
2009 MX-5 STR and track toy
Anyone in the metroplex rebuild motors? Replace crank, bearings, etc.?
I haven’t torn it down yet, so no pics. The car would barely run and when it did the crank was wobbling really really bad. I can't imaging the crank and key are gonna be very repairable, and I'm not real impressed w/ the "loctite" fix either. Either way, the motor has gotta come out so I need to use the situation to my advantage. I'd really love to get a newly built FM motor, but I'm just not real sure I wanna drop 4k on new motor. My car only has 80k miles on it and is in pristine condition so getting a used motor w/ 120k or higher miles make me cringe.
I've used Arlington Machine in the past for engine work, as have a couple of car buddies. While I haven't chosen to have them reassemble complete engines (because I'm sometimes a cheap bastard), I do believe that they offer this service.
817-two six one-9022 is their number. Talk to Eddie.
I had always heard that it was way cheaper to replace the entire engine than to repair a LWSC (Light Weight Sport Crank) failure, unless you did the all the work yourself. If you find out differently, please let us know.
Yep, you can usually pick up a decent take out engine for $400-800 complete.
There should be, Eric Japan is the one of the more popular places to buy one. I bought one a couple years ago and I installed another one from them in a friends car about a year ago.
I haven’t had time to pull the I/C pipes out of the way but I did inspect the front of the crank pulley from underneath the car today, and it looked normal. The main center bolt looked fine and the 4 small outer bolts looked fine too. The crank pulley is not loose as far as trying to move it by hand. What should I be looking for?
I took some quick vids of the wobbling that concerns me.
http://www.youtube.com/watch?v=1apfMgWhsPo
http://www.youtube.com/watch?v=agAE6Z_7lV4
Yikes... yeah that looks like a little bit of a wobble.
