Did you remove the screw??
Does this thing just pop out? I tried but don't want to break the plastic, which seems kind of fragile.
An entire new Master is $19.99 at O'reilly's.
Well, I bought one just a few months ago and installed it a few weeks ago.
Guess I shoulda done it a few weeks ago, cause both AZ and O'Reilly are now at $35.
I was thinking of the clutch master cylinder. You should've known that Rogue.
Got the reservoir out, got the new grommets in. Now I can't get the reservoir all the way back in, no matter how much pressure I put on it .
Just need a little lubrication!
Finally!!! It was lubed up with synthetic brake grease and DOT 3 but just when I thought sure it was going to break, it was in.
