Page 1 of 7 123 ... LastLast
Results 1 to 20 of 124
Thread: No good deed goes unpunished...
    Question No good deed goes unpunished...
    So this morning on the way to work, the Miata starts sputtering/misfiring like it's not getting any gas. I get to a stop light and see steam
    coming out from under the hood. It appears when I replaced my crunchy heater hose grommets, I disturbed the delicate balance of the
    stupid hose clamps!
    My question is, would the moisture/steam under the hood make the car run crappy? I was able to limp it back home and the temperature
    never came up.
    Yep if you got something electrical moist it could certainly cause it to miss.
    It's home in the garage, with the hood up. Hopefully it will dry out.
    And this is why we can't get you nice things.....
    Water squirting onto coil perhaps.
    1997 Miata - Weekend\Autox Car
    1994 Mustang Cobra - Garage Shelf
    2012 Mazda 3 - Daily
    Quote Originally Posted by Labora View Post
    Could very well be...very close to the heater hoses.
    PS - I probably need to break down and replace those hoses.
    I had one break after doing donuts. Luckily I was able to loop the lines and limp it home without a hose clamp. If they are old/brittle I absolutely would replace them.
    I know Rosenthal sells the complete coolant hose kit. Does Mazda sell a similar kit I can order?
    Or...does anyone have all the part numbers handy for a '93?
    MazdaMotorSports:
    0000-01-HOSE-16 1 @ HOSE KIT, 90-93 MIATA
    Notes: ALL COOLING HOSES
    Miata ALL 1990 - 1993 $64.03
    not sure what hoses it includes - Better Call First!
    1995 M Edition
    ^Thanks Gabby!
    Just added to my cart, and checked availability. It broke it down into all the part numbers...it appears to be complete!
    0000-01-HOSE-16 @ HOSE KIT, 90-93 MIATA N
    >>C B61P-15-184 HOSE,WATER 1 11.71 11.71 N
    >>C B61P-15-185 HOSE, LOWER WATER 1 6.43 6.43 N
    >>C B61P-15-186 HOSE, UPPER WATER 1 8.16 8.16 N
    >>C B61P-15-261A HOSE,WATER 1 5.87 5.87 N
    >>C NA75-61-211 HOSE NO.1,WATER 1 10.07 10.07 N
    >>C NA01-61-212A HOSE, WATER 1 11.72 11.72 N
    >>C B61P-13-681B HOSE,WATER 1 4.29 4.29 N
    >>C B61P-13-682A HOSE, WATER 1 4.29 4.29 N
    >>C B61P-13-691A HOSE,WATER 1 6.01 6.01 N
    >>C F8L7-13-104 CAP,BLIND 1 3.04 3.04 N
    Are these all correct for your cheate...uhhh JMD motor?
    1995 M Edition
    ^We don't use the 'C' word! Yes they are.
    Sorry - POS Racing is rubbing of on me - eeewwwww!
    1995 M Edition
    Replaced the OEM hose clamp with a screw drive one. Let it run and get up to temp in the garage last night without any signs of leaking. Tried to drive it to work this morning, and got a few minutes away from home and it started sputtering again. Still no signs of leaking. I'm hoping it just hasn't dried out yet....it's back in the garage again with a fan pointed at it.
    Any other ideas?
    I would pull all the spark plug wires and make sure you don't have water down any of the holes. If you notice any moisture you can try putting some WD-40 on the ends of the wires.
    ^Good idea, thanks!
    Did it just spew or did it overheat? If the head got too hot and warped, you could be having bigger issues.
    ^Never overheated. Just leaked and steamed inside the engine bay. Header wrap can create a bunch of steam when it gets wet.
    Still no bueno. No water in the plug holes, but I removed the wires and gave them, the coil and the holes a squirt of WD40 just for grins. I cleaned the MAF plug with electronic cleaner too.
    It ran great for a few minutes, then started sputtering. I limped along, and eventually it ran fine again.
    Did that a few times before I brought it back home. I'm stumped. Almost acts like water in the fuel line...is that possible?
    Ground wires?
    1995 M Edition
  1. Good one
    By Squid in forum Bull
    Last Post: 09-13-2011, 09:40 AM
  2. Yea that's not good either.....
    By POS Racing in forum OTM Tech and Chat
    Last Post: 01-21-2007, 06:48 PM
  3. Not having a good day.
    By black roadster in forum Miata Tech and Chat
    Last Post: 10-29-2006, 01:48 AM
  4. It's Good To Be A Man
    By sammm in forum Bull
    Last Post: 08-31-2006, 05:49 PM
  5. Yea that's not good....
    Last Post: 07-29-2005, 07:06 AM
