Results 1 to 8 of 8
Thread: 96 Miata Dash Help
    Tire Warmer
    Jul 2005
    Sarasota, Florida
    Default 96 Miata Dash Help
    Hey guys, nice board, my fathers 96 Miata has the following components not working:
    Tackometer
    Fuel Gauge
    Water Temp
    Oil Pressure
    Cruise Control
    They all stoped working at the same time, if you have any ideas, please share.
    Mark M.
    Did you check the main fuses/relays under the hood?
    Tire Warmer
    Jul 2005
    Sarasota, Florida
    Yea, its not fuse..any other ideas?
    Mark M.
    Should be something simple like a fuse or something disconnected, but if worst comes true Mazda Haven had plenty of 94-97 dashes and guage clusters last time I was out there.
    Quote Originally Posted by mm84
    Tackometer
    Fuel Gauge
    Water Temp
    Oil Pressure
    Cruise Control
    Welcome to the board, Mark.
    Hmm... came across something that might help you in this other thread:
    Quote Originally Posted by gene501
    ...Word to the Wise: Unplugging the harness under behind the glove box will disable your temperature, oil pressure, and rpm gauges. :afro:
    Sounds like this might be your problem - I can't imagine another reason that those five things would all stop working simultaneously, except that somthing has come unplugged in the harness. This sounds like a good place to start.
    I had that problem on my 96 last year and it was a fuse under the dash. It turned out to be a short in the reverse switch on the trans so every time you put it in reverese no gauges. I replaced the switch and all is fine.
    Tackometer
  1. Miata vs. Exploder
    By Jiggerachi in forum Bull
    Last Post: 07-01-2005, 11:28 AM
  2. Traded Miata For...
    By srivendel in forum Bull
    Last Post: 04-01-2005, 09:08 AM
  3. Miata Heaven, first trip there!!
    By Champion1 in forum Miata Tech and Chat
    Last Post: 11-26-2004, 03:13 PM
  4. Driver Death Rates...Miata
    By general default in forum Miata Tech and Chat
    Last Post: 05-10-2004, 06:10 PM
