Results 1 to 19 of 19
Thread: Changing complete brake system on white, which fluid to use?
    Driver Ataim's Avatar
    Jun 2004
    About 7 miles north of Billy
    Default Changing complete brake system on white, which fluid to use?
    I've bought all new brake components and have read the dot 5 is not good to use. But dot 5.1 is ok. Am I reading this correctly? Or should I just stick with plain ol dot 4?
    P
    Valvoline Synthetic...pick it up at Vatozone.
    Unless you're at the track every day, DOT 4 should be just fine and then some. Just remember that once you go to DOT 4, you need to stick with DOT 4 or better - don't go adding DOT 3 to DOT 4 (at least that's what I've always been told).
    And +1 what sammm said about the Valvoline Synthetic...
    +1 Good Stuff!
    Jun 2004
    +1 Good Stuff!
    I guess that's it! Now all that I have to do is some wrenching
    +1 Good Stuff!
    Hey what a surprise that is what is in my car too!
    Same here. In fact, this is my 3rd car to get this fluid.
    Magma is also running this in his MSM.
    '06 RSX Type-S NBP
    Supporter wrxmr2eater's Avatar
    May 2005
    Morrisville, NC - former Texan
    Ok, I'm a snob I guess.... I use Motul RBF 600. The higher boiling pressure is nice, but the resistance to moisture is what I like best.
    Just so you dont think I throw money away, I don't pay any where near retail for it.
    Quote Originally Posted by wrxmr2eater View Post
    +1
    Erm... Motul RBF600 is actually a lot more hygroscopic than most other brake fluids out there. In other words, it absorbs water at a much faster rate than something like Valvoline Synthetic.
    Motul does have a higher dry boiling temp than Valvoline, but that great dry boiling point is useless if you're leaving it in the car for more than six months between flushes.
    FWIW, I use Valvoline Synthetic on my cars for daily driving and autocross use, but I'll flush the system with Motul for track days.
    Oh, and real brake fluid snobs use Castrol SRF.
    you cannot mix dot 5 with anything but dot 5 because it is more silicon based. you can interchange 3 and 4, but if youve got 4 in there you might as well keep 4 because of the boiling temp.
    http://auto.howstuffworks.com/question451.htm
    http://www.raceshopper.com/brake_fluid.shtml
    The only think I could keep from eating all of the seals out in my old FIAT was Castrol LMA which is a Dot 4 brake fluid. Haven't tried Valvoline, but will definitely will give it a try, now with the overwhelming recomendation of the group here.
    Hmm...interesting info, thanks!
    May 2005
    Sorry, I was meaning the resistance to moisture as in moisture beading in the lines. It does absorb, but I am flushing brake fluid at the most every 3 months - usually sooner.
    SRF is fabled, but that is Macallan scotch pricing, but Wilwood EXP 600 Plus is intriguing.
    dot 5 supposedly does not absorb water. and it doesnt disolve paint!
    Go ahead and use some Skydrol.
    It's purty Purple and full synthetic. JK
    I use Motorcraft High Performance DOT 3. Great stuff for the price, $4.20 for 12 fl. oz. at any Ford dealer, 550F dry and 288F wet boiling points. Not bad when it's changed as often as we do.
    Last edited by cone-cerned; 02-16-2007 at 03:23 PM. Reason: Trying to get it right.
    Quote Originally Posted by Mingle View Post
    It is also a highly compressible fluid, which equates to a very squishy brake pedal. Dot5 fluid should be completely avoided on all tracked or autocrossed cars, imho.
  1. White and Nerdy
    By Majik in forum Bull
    Last Post: 09-18-2006, 03:37 PM
  2. brake fluid suggestions
    By BAM! in forum Miata Tech and Chat
    Last Post: 05-02-2006, 09:07 AM
  3. Need help changing Brake Fluid
    Last Post: 10-05-2005, 10:11 AM
  4. Pics and details on the C6 Z06
    Last Post: 01-07-2005, 01:04 AM
  5. What Brand Of Brake Fluid?
    By gabkwong in forum Parts is Parts
    Last Post: 08-12-2004, 06:58 PM
