Results 1 to 17 of 17
Thread: 10psi Greddy Turbo w/ AEM EMS
    Default 10psi Greddy Turbo w/ AEM EMS
    First run was 10psi, untuned. I didn't put the torque on it cause it was having issues with the RPM pickup, so the readings are either spikey or missing a big chunk of the line.
    I was running 210whp/186tq.
    I am now running 223whp/191tq thanks to some tuning.
    Default where at
    nice numbers @ 10psi, I have some fine tuning to do once I figure what I am doing.
    where did you go? Alamo?
    Buck
    04 MSM reflashed and modified
    "Fish tremble at the sound of my name"
    Yes, Alamo. Consistent dyno to give consistent numbers.
    post up a graph with RPM's. Nobody cares about speed unless it's a dyno queen.
    what he said :)
    It's not very good...but here it is
    Quote Originally Posted by johnwag View Post
    I like showing that I can run 102mph in 3d gear now.
    Quote Originally Posted by ray_sir_6 View Post
    That is pretty cool. Nice numbers Ray.
    So are you liking the AEM more and more? Run into any problems yet?
    Whenever you hit your max PSI, you should do a tune with e85 and see what kind of numbers that'll produce.
    <---Jealous of your standalone.
    Chris
    http://austinmiata.com/
    Quote Originally Posted by Miatamaniac92 View Post
    Chris
    I don't have enough injector to run E85. I like the AEM more and more everytime we turn the boost up and retune. I haven't had any issues with it yet, it runs very well. We'll be playing with launch control and flat-shift soon enough.
    How does it recognize a flat shift? Clutch switch and then activate a soft rev limit (same as launch control as well)?
    Chris
    Chris
    Yes. Too bad I don't have ABS, or I could use the traction control as well. I am gonna find some hubs and sensors and install them so I can run it later on, but for now I have to do without.
    Good luck with that mod. From what I've heard you need the donor next to the car to succesfully add ABS to a non-ABS car. That's a pretty cool feature though.
    Chris
    Chris
    I don't need ABS, I just need the wheel speed sensors. I just wire it into the EMS and, BAM, traction control. I can also get mph off it, for when I go to a STACK.
    STACK? MAP, MAF, wet finger?
    Chris
    STACK display.
    Bitching, more info please. Looks considerably less than a the other displays that many other racers use.
    Am I correct that the digital gauges are user definable?
    Chris
    That isn't the exact one I am getting, it was just the first pic I found to link to. I am getting black, 10k rpm version. I'm gonna use the ones my friend uses in both his SM and ITA Miatas, plus his 2 GTA cars.
  1. Greddy 1.6T Kit
    By ray_sir_6 in forum FI Miata Tech & Chat
    Last Post: 02-25-2007, 01:03 AM
  2. Turbo Kit on the way
    By Carmen1990 in forum FI Miata Tech & Chat
    Last Post: 08-23-2005, 10:10 AM
  3. The Greddy Emanage is in!
    Last Post: 02-03-2005, 10:13 PM
  4. Ordered the Greddy.....
    Last Post: 12-15-2004, 06:23 PM
  5. How many Greddy Turbo guys are here?
    Last Post: 08-13-2004, 03:29 PM
