Results 1 to 8 of 8
Thread: Your car is Phat!
    Default Your car is Phat!
    At the SCCA Test and Tune we were able to run a few Miati over the scales! Here is what we saw:
    • Mark52 '96 Base 2,135 lbs w/o driver *
      POS '92 "C" Package 2,193 lbs. w/o driver
      Stoltz '96 M 2,350 lbs. w/o driver
      General Default '99 Sport 2,267 lbs. w/o driver
      Altiain '99 Sport 2,311 lbs. w/o driver
      onething '01 LS 2,403 lbs. w/o driver
    *Don't ask what's in the trunk!
    How much is the New Elise suppose to weigh again?
    Chris
    http://austinmiata.com/
    Quote Originally Posted by Miatamaniac92
    Chris
    1950... Just sneaking under the 1 ton mark
    After the weighing, I went home and weighed my race tires/wheels as well as the stock seats and race seats. So, in full race trim, CSP52 should weigh-in at 2,060. :o Of course that does not include the driver or that "stuff" in the trunk.
    Driver BigDmiata's Avatar
    Just west of East (land of Gar)
    BigDmiata '97 Touring 2,150 lbs. w/o driver
    2013 Mazda2 slushbox daily
    Default Re: Your car is Phat!
    Also of note - while my car was 2311lbs, that was in street trim on "Empty". By comparison, General Default's car was 2267 in autox trim with a 1/4 tank of gas - no spare, floormat, etc. When we rolled his car across the scales in street trim, it was about 2294#, iirc. So it would appear that the additional weight of my roll bar is somewhat compensated by the lack of power steering.
    I would have liked to have weighed John Baker's Sport, since it has no roll bar, power steering, or a/c.
    I wanna get rid of my PS. I'm sure the big ol turbo weighs a lil more than that, which might offset the weight a bit.
    On the Elise point, Lotus USA quotes:
    "Weight:
    757Kg* [1665 lbs]
    Unladen weight 806*
    [1773 lbs] (including full tank of fuel)"
    Car and Driver quotes:
    "2005 LOTUS ELISE
    Vehicle type: mid-engine, rear-wheel-drive, 2-passenger, 2-door roadster
    Estimated base price: $39,000
    Engine type: DOHC 16-valve inline-4, aluminum block and head, port fuel injection
    Displacement: 110 cu in, 1796cc
    Power (SAE net): 190 bhp @ 7800 rpm
    Torque (SAE net): 133 lb-ft @ 6800 rpm
    Transmission: 6-speed manual
    Wheelbase: 90.6 in
    Length/width/height: 149.0/67.7/44.0 in
    Curb weight: 2000 lb"
    Hmmmm. I'll believe Lotus until it actually hits the streets, or if someone has a better source.
    But still 1700 would be 400 - 500 lbs under light M1's.
    Chris
    "Weight:
    757Kg* [1665 lbs]
    Unladen weight 806*
    That would be under the section on Lotus USA's website entitled: Elise Specifications - (U.K.) - U.S. version will be slightly different. :P
    Don't forget that the 111s that they've taken the specs for doesn't have ABS, a/c, power windows, the Toyota powerplant or 6-speed tranny, etc. All the indications I've seen say that the U.S.-spec Elise will be just under 2000 pounds.
