Results 1 to 7 of 7
Thread: Parallel fan wiring
    Suspension Modder crna2be's Avatar
    Jul 2004
    Tom Bean, TX(Waaaaaay North Dallas)
    Default Parallel fan wiring
    Has anybody tried this? I use my Miata to commute about 50 miles one-way M-F. The last 6-7 miles are stop and go. When the weather gets hot...it's mostly stop for me.
    Looks like I am getting ready to do a complete rebuild. Since I have to take all of the accessories and the timing belt off just to get to the water pump...might as well.
    Mike
    Never raise your hands to your children...it leaves your groin unprotected!
    You can try two things
    1. parallel wiring (Search the garage section of Miata.net)
    2. Use a temporary jumper in your Diags box during the summer to turn the fans on with the ignition.
    93 FMII + LOTS MORE
    The Black Mamba
    Jul 2004
    Have the Miata.net article, thought I would try it.
    However, there is some concern expressed at the end about the ability of the relay to handle the extra current. The concern is only theoretical, so, I thought I would see if anyone was actually using that set-up in this area.
    Thanks again.
    I have been running in parallel and ignition on for the whole summer.
    93 FMII + LOTS MORE
    The Black Mamba
    If you are really worried, jumper the fan relay at the DIAG control and then both fans will run off their own relay. Plus you can just pull the jumper if you want to reverse it.
    93 FMII + LOTS MORE
    The Black Mamba
    I've had parallel fans for almost 2 years and no problems, related to the fans at least.
    Jul 2004
    Perfect gents!
    Thanks...I am going outside now to parallel my fans and go ign on.
    M.
  1. 99 Wiring Diagrams
    By EvilSpeeder in forum Miata Tech and Chat
    Last Post: 06-05-2005, 09:23 AM
  2. wiring
    By Dave in forum Miata Tech and Chat
    Last Post: 12-22-2004, 11:40 PM
  3. Wiring (Treil Drei)
    By Treibenschnell in forum Miata Tech and Chat
    Last Post: 12-16-2004, 07:02 PM
  4. Wiring Conundrum - Con't.
    Last Post: 12-12-2004, 02:57 AM
  5. Parallel parking your Miata, Game
    By general default in forum Bull
    Last Post: 06-10-2004, 04:26 PM
