Results 1 to 15 of 15
Thread: It's HOT in here!!!!
    Chassis Designer
    Dec 2007
    Frisco, TX
    Blog Entries
    2
    Default It's HOT in here!!!!
    This is probably so elementary you guys have already got this figured out but....
    I notice a ton of heat coming off of the 'hump' in the middle of the car. Especially through the shifter but really along the hole middle of the car, over the drive shaft.
    Has anybody figured out how to insulate this area so it's at least bearable?
    Your shifter boots are torn. Replace them, and all will be better.
    +1!
    Good stuff here - http://www.camsmx5.com/Resources/tec...techshift.html
    +2 ... #13 and #14 in the picture. You can find them cheaper elsewhere.
    While you're in there, you might as well replace the nylon shifter bushings.
    Quote Originally Posted by Darron65 View Post
    Cool graphic Sammm!
    Yea where did you swipe that?? It is cool!
    Thumbs up
    Cool graphic Sammm!
    www.miatamania.com
    When you replace shifter boots and nylon bushings, please add oil to the shifter turret. It will be about 3 oz. It will make your shifter smoother!! Good luck...
    Wow, you guys are cool. I wish I had a Miata.
    Says the in the precious car.
    So....how is the search for the replacement going? (this time)
    Another RARE Miata flyin94m's Avatar
    Nov 2006
    Double Oak, Texas
    For snicks, grins, and giggles, jumper TEN and GND to see if you throw any codes. I noticed the same thing on my NA right before my fried.
    Quote Originally Posted by Jeremy Clarkson
    There's no six-way traction control. There's no complicated folding metal roof. It's simpler than that. Engine in the front, drive to the rear, and a big smiling piece of meat in the middle.
    Currently:
    1991 Mariner Blue (daily driver)
    Previously:
    1994 M-Edition
    Yeah, yeah!
    BTW, will you be instructing with Apex on May 3rd?
    Quote Originally Posted by smartmx5 View Post
    Unless you have a 6 speed
