![Quote](images/misc/quote_icon.png)
Originally Posted by
black roadster
This is not an easy install. You will need to pull the top and frame off the car. Check the condition of your top. If worn, you might as well order a new top with rain rail installed. Check the cables. If frayed or broken, they will need to be replaced. You need to tighten the nuts in a specific sequence where the rain rail mounts to the body. Finally, you need to make sure the rain rail is installed correctly around the rubber belt at the base of the top. The one mounted to the car.
