Build one of these caps!
No need for speedbleaders and it will work on any year Miata!
Anyone out there use 'em? Anyone care to comment good/bad regarding them?
Also, where in the heck do you get 'em? I can't find 'em at any of the typical Miata part sellers online.
I second that! The pressure cap is the only way to bleed/flush your brake system! (Don't mention a Mity Vac either cuz they'll be on you like a chihuahua on a pork chop! :P )Originally Posted by POS Racing
Bark, Bark, Bark, Bark!Originally Posted by sammm
I said notOriginally Posted by POS Racing
The problem with MityVacs isn't that they suck, it's that they don't suck enough.Originally Posted by sammm
Seriously though - build one of the caps that POS mentioned, hook up to your air compressor, and sit back and marvel that you hadn't thought of this before. It really takes the work out of a brake fluid change.
It's pretty simple fill the reservoir screw on the cap hook up an air line(20 PSI or less will work), then open the bleed screw on the caliper farthest from the master cylinder then work you way around to all four screws. No helper required, just make sure you check the reservoir on occasion!Originally Posted by droptop
It takes longer to pull the wheels than it does to flush the entire brake system using the cap!
The best part, though, is when you're bleeding an ancient wonder of the third world on which one of the bleeder screws is clogged... I was really impressed by the way brake fluid aerated when we got the pressure up to 27 psi...Originally Posted by POS Racing
