Results 1 to 17 of 17
Thread: Headlight Out
    Default Headlight Out
    How do I get the bulb out?
    Highlight Silver & Tan 99 "With a Style Bar"
    Everything else just "Depends"........
    Quote Originally Posted by riverracer
    Owner's manual? Too bad you didn't ask sooner. I would have gladly changed yours if you had swapped the ones in my wife's Civic... Those are a serious PITA!!!!!!
    I don't have one....
    Just go to any hardware store they all sell hammers!
    That looked like a special Brit hammer...
    TC I know about the Civic... I have one....
    Now tell me about this car...
    I got an '02... much more room.
    Same principle as the Civic... unplug harness, remove seal, unclip bulb, remove bulb. Never touch bulb glass. Never handle hot bulb. Or, if really bored, get bulb hot, quickly remove, and drop in (large, distant) bucket of ice water.
    thanks...
    thanks...
    It should be detailed in the owner's manual... Maybe someone has one and can check the specifics (like the Civic trick where the power steering reservoir is quick release so you can pull it out of the way...)
    Quote Originally Posted by tailchaser
    I'm scanning it now!
    I got it out...It was the passenger side...more room there...
    Fancy that... bang on identical to the Civic... shocker with it being the same bulb, and all...
    It was easier than my Civic....The clip didn't fall off and make me look for it.. Thanks POS & TC
    Would you expect any less from the "slightly cynical and abrasive, but extremely helpful" Miata board?
    First time I changed the Civic lamp, I sent the driver side spring into another zip code. Learned to use a flashlight...
    I got just what I expected TC....A little friendly banter and then the answer...
  1. Headlight problem
    Last Post: 01-26-2005, 05:13 PM
  2. Cold Air Intake for M2's?
    By Thorage327 in forum Miata Tech and Chat
    Last Post: 11-12-2004, 11:49 PM
