Threads 1 to 16 of 16
Forum: Engine Management & Tuning
Stand alone engine management, tuning, and general EFI. Whether you've added boost and need more fuel or just want to eke out as much as you can from a naturally aspirated plant, this is the space for you.
  1. Speeduino project
    Started by Vissi, 11-01-2015 08:56 PM
    01-07-2019, 04:22 PM Go to last post
  2. 3.5 Liter Acura
    Started by shortshift, 01-16-2016 10:45 AM
    01-17-2016, 04:39 PM Go to last post
  3. Moved: need help changing timing belt
    Started by twinbee, 05-23-2015 09:19 PM
  4. Got a blog about MEGASQUIRT - hope you like.
    Started by elior77, 02-13-2015 02:07 PM
    02-13-2015, 02:07 PM Go to last post
  5. Who needs MS tuning?
    Started by SirHustlerEsq, 06-28-2012 10:07 PM
    2 Pages
    1 2
    10-13-2014, 10:16 AM Go to last post
    06-17-2014, 06:25 AM Go to last post
  6. Exclamation MSPNP2 3.3.0 fw upgrade (99-00) correct firmware?
    Started by luis, 01-11-2014 10:55 AM
    04-19-2014, 11:01 PM Go to last post
  7. Worth the buy?
    Started by mtrx804, 04-13-2014 09:05 AM
    04-13-2014, 09:42 AM Go to last post
  8. No-weak crank signal
    Started by baker99miata, 03-31-2014 09:08 AM
    04-01-2014, 10:32 PM Go to last post
  9. 1997 Turbo Engine in a 1999 Car
    Started by Barry 99 Turbo Miata, 03-10-2014 06:19 PM
    1999, ecu, turbo, wiring
    03-17-2014, 09:12 AM Go to last post
  10. a/c idle up MSPNP2
    Started by luis, 02-01-2014 11:07 AM
    02-03-2014, 08:49 PM Go to last post
  11. Dynotronics ECU Reflash Discount opportunity
    Started by OZMDD, 01-16-2013 09:10 AM
    2 Pages
    1 2
    05-31-2013, 08:26 AM Go to last post
  12. Shadow Dash is bause
    Started by SirHustlerEsq, 11-01-2012 09:59 PM
    11-02-2012, 03:45 AM Go to last post
  13. Megasquirt 2 on 99 help
    Started by speester1, 05-03-2012 01:45 PM
    08-05-2012, 07:25 PM Go to last post
  14. LC1 preferred grounding location
    Started by Flyin96M, 04-15-2012 10:44 AM
    04-18-2012, 08:17 AM Go to last post
  15. You can tune an engine but you can't tuna fish.
    Started by Nails, 04-05-2012 12:06 PM
    2 Pages
    1 2
    04-07-2012, 11:33 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 250 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
